Adding a wall light from a switch?
1 Mar 2007
London
Hi
I'm trying to add a wall light at the bottom of my stairs, which I connected to a switch that powers the light at the top of the stairs.
I connected it up and tried out various permutations through what i believe to be a two way switch but all I get when I switch it on is a dull glow. What am I doing wrong?
Should I be adding a fused spur? Don't see how this woudl help?
jimmyjames said:
Hi
I'm trying to add a wall light at the bottom of my stairs, which I connected to a switch that powers the light at the top of the stairs.?
You need to take a two core and earth cable from the existing lamp to the new lamp. The lamp needs a switched live and a neutral
Very few switches have a neutral in them. There is live and a switched live but without a neutral you cannot run a light. The ceiling rose has a neutral.
The dim light was when you connected the new lamp across the switch. It was then in series with the other lamp so both would come on but at low light levels as the 230 volts was shared between them.
I did connect the new light to the existing switch via two core cable with earth. But just to make sure I understand you, are you suggesting i connect this to it's own switch?
I see. Trouble is I don't have a lighting circuit anywhere near where I want to situate this new walllight.
I sense I'm getting to the reason why nobody put a light there in the first place!
I geuss what I really need is a pot of filler and some paint to mend the mess I just made!
Great. Thanks anyway
he he he
I may be stupid but I'm not that stupid. There is no power source anywhere near where I needed teh wall light.
