Adding additional radiator to Economy Seven system.
25 Sep 2012
Kent
We have a small house with Economy Seven storage heating and we are now having a small extension built. Is it easy/possible to add another heater to the existing system?
Thanks for any help.
Ron
Are there any spare ways in the Board? Have you pictures of your current set up?
Economy 7 is a tariff not a system, the old system used often had a fuse per radiator typical a row of 16A, it would likely need a cable all the way back to the fuse box to add an extra, and also likely a problem getting RCD protection on the new cable.
Later systems would often have multiply units per circuit and it is a case of adding up and see what power is to spare.
So step one is find what you have.
