Adding another radiator Daisy chain.
Of course it works, it's actually the most efficient way to do it.
I know the Energenie TRV head is claimed to have two sensors so it will compensate for the heat direct from the radiator, however in the main, we can't use the top entry on the radiator and have the TRV low down on the supply side, one way or another we have to compromise, be it put the TRV on the return, or the supply into the bottom, pre the TRV it was common to put the feed into the top, and to insulate the feed pipe, there is also an argument over using over sized pipe work, as this can also over heat the TRV head.
