Adding high level socket Spur for TV
31 Dec 2012
Durham
Hello, I want to add a mid wall socket for a wall mounted TV, the wall is dot and dab
At the bottom of the wall I have a TV aerial socket, then a double socket and finally a box thats pre-wired for virgin media - which i don't use/not connected
I want to spur off the double socket, but there is full length plasterboard adhesive above the socket so channeling will cause a lot of mess
I was considering removing the virgin media cables leaving the metal back box, running a cable into there from the double socket, adding a double pole switch (20amp?) and then going up the wall to a un-switched double socket for the TV?
This would give easy isolation if i need to hard reset the TV/Q box, keep cables in safe zone and also make the drop down from the socket easier as the area is totally clear of adhesive.
Does this sound ok from a regs/safety point of view?
Great, it seemed to make sense to me, but wanted to check my opinion
So what about the aerial and satellite cables. Will you extend them as well?
