Hi all
I need to add a double socket behind a wall mounted TV. This socket would be used for an LED TV (71W power consumption) and maybe a Sky Q mini box in the future.
Only real feasible solution is to spur from the lighting circuit in that room. Socket would never be used for anything other than listed above and would be positioned 6 feet up the wall behind the tv.
Is this possible?
If so, would the spur need to go to a FCU first, then feed the socket from there?
Thank you.
Is this possible?
Thank you.
