Adding light to existing circuit?
Hpd
23 Feb 2011
Cardiff
Hi Im wanting to fit an outside/porch light with its own switch. The nearest existing light is the hallway pendant. I have lifted the floorboards above and there are two cables going to the ceiling rose (one twin and earth IN and the switch cable) so presumably this is the last light on the circuit?
Just would like to know the best way to wire the new light and switch? Happy to chase walls etc as its all getting re-plastered anyway
Thanks!
If there is a permanent live ,neutral ,and earth available at the hallway pendant ,then you can pick up the supply from there . Take it to your switch ,and on to the external light .
Is the circuit protected by an RCD ?
What specifically do you want to know ?
Why would you want to introduce a junction box ,when you can wire directly from the rose ?
Take the cable to a double pole switch ,and from there to your light fitting.
1.5 T&E cable is fine.
  • Thanks
Reactions: Hpd
I wasn't sure which was the more correct method that was all! Thanks for the help though, no junction box it is lol
