Adding new radiator
28 Aug 2009
Kent
Hi
I want to fit a new radiator to the existing CH system. The 22mm flow and return pipes from the boiler are buried in the concrete floor of my bungalow. Is it OK to T-off the 15mm pipes above the floor feeding an existing radiator?
Any help gratefully received.
Red
Unless you are fitting a very large radiator son, you'll be fine teeing off the 15mm F&R going to an existing radiator. A 15mm pipe can carry a 6KW + heat load.
It will be a very small rad as it is going in the loo.
Thanks for your help
Red
Forgot to say Red; You need to ensure you have a two pipe system!!
If your house/system is no more than 20 years old you'll be fine.
The property was built in early sixties, I'm certain it has a two pipe system. Thank you
No problem.
What a lovely part of the world you live in and the weather has been kind to you this Summer also!!
Dick, you have made me wonder whether I have a 2 pipe system. Is there an easy way to tell, by looking at the pipework around the hot water tank?
If the system was installed in the 60's then it may be one pipe?!!
The best way to check is if there's a one pipe loop around the system & one pipe passing under the rads, with the radiator F&R connected to one horizontal pipe.
On a lighter note, here's a link to our Plumbers song, enjoy;
http://www.youtube.com/watch?v=uLvR7VMWCUY
:lol: :lol:
Its not easy to check the pipes as they are under concrete, but there are two drain cocks for the system outside. I'm assuming that this indicates two pipes. Also I had a new boiler fitted in 2006 by a reputable company, am I right in thinking that it is against regulations to fit a new boiler to a one pipe system? Or am I talking out of my stopcock!
If you have two drain off points terminating at the same point then this would indicate a two pipe system.
No, you can fit a condensing boiler to a one pipe system. If you couldn't then a lot of homes would find a simple boiler swap very expensive.
"Stopcock",, :lol:
