If i have a 20A MCB at the consumer unit can i change my cooker 45A DP isolating switch to a 2 gang 45A DP cooker switch with 13A socket using a single to double backbox converter to save me digging out the wall.
Also can i safely run a spur off the cooker wall plate cable outlet to fit a socket for gas hob electrical connection which is only 3A
I am fitting a new intergrated oven which the manufacturer requires 15-20A fuse and 2.5mm flex connection.
Any help appreciated
