- Joined
- 2 Aug 2019
- Messages
- 68
- Reaction score
- 2
- Country
Hi, I would like to install as a single lighting solution, four LED panels with four drivers. So the load is quite low.
Can I intercept a lighting circuit feed to an existing light to power them. Is there any issue with having four feeds to the drivers. If so, how can I address that and stay within regs?
Physical options would be to run four cables from the existing supply in a star network to each driver or secondly to have a daisy chain - one feed from existing supply to the first driver, then connect the next driver up etc.
I'm simplifying this a bit, as I know that I will need a switched live too, to turn the panels off and on.
I will use an electrician, just want to check that there is a sensible solution.
