I have 10 IP65 LED lights each of which has 15 led,s within. Can I run them on a single circuit from the driver to the last light or do they each need a seperate feed from the driver? Can anybody help please>
In an attempt to be slightly more useful, LED lighting supplied with a driver is usually wired in a series chain as the driver provides a constant current source and will vary the output voltage as necessary. That doesn't mean yours will work this way for sure.
