Alternative transformer for LED
That's encouraging.
I did think of suggesting asking them if you could use ANO driver, but then I thought they'll just say "use ours or we can't guarantee that the lights wont, through a process known as 'tunneling,' spontaneously disappear from their present locations and reappear at any random places in the universe".
Good for them.
Maximum voltage is 50 volt or not extra low voltage so needs 20 volt per lamp so you may be able to run two lights off one driver that's the best anyone can do.
A MAX16804 chip will cost around £4 and you could build your own power supply
likely most of the drivers have one of these inside. There are units for £14 but really for the trade but I am sure you can hunt out cheaper. But however you do it your really stepping into a rather technical field and personally I would want to use a more common system that you can if required select replacement parts from the high street.
