Hi there, a question for you... I have a 1972 house with an open vented heating system as follows:
In loft: cold water tank and heating vent cold water tank
Upstairs landing airing cupboard: hot water cylinder, pump, 3 way motorised valve (Y plan), drayton wiring centre
Upstairs landing: Honeywell controller/programmer for water/heat
Downstairs: roomstat
Downstairs utlilty room: 17 year old oil boiler.
The boiler is broken (rusted water jacket) and I was going to get it replaced with a Worcester Greenstar Utility 18/25 oil condensing boiler.
The point of the post is: at the same time I am building a conservatory right beside the utility room (i.e v close to the boiler), so the question is: if I was to fit direct boiler control underfloor heating in the conservatory:
1) Can I tee off directly from the boiler flow/return to the UFH (for example the nu heat onezone kit). I ask this because all the schematics on t'internet from various suppliers show the boiler flow pipe, then the pump, then the tee off to the UFH. Obviously with the pump upstairs I would prefer to tee off by the boiler.
2) My current boiler or the replcament Utility 18/25 does not (as far as I know) have pump overrun, if it did does this change anything.
Many thanks!
Many thanks!
