Adding x100 to top of towel rail
17 Feb 2006
Draining the CH. Don't really know how to add inhibitor, but when everything is connected up again the very highest point will be the top of a towel rail. Which will have a bleed valve in it. If I just take off the whole bleed valve bit I've got a hole, facing upwards, I can slot a funnel into to add X100. Will that work? Or is there a better place to add it.
Cheers, Mike
would work just fine, if its vent you could put in f and e tank before you refil the system.
