We recently converted our loft space into another bedroom, we built a cupboard up there to hold the cold water tank and the smaller heating expansion tank. Both tanks are in the same place pretty much as they were before sitting on the floor.
We then added a 600mm radiator by tapping into the flow and return from the floor below. The radiator bleeds fine and heats the loft room well but after a while it fills with air again, this looking back is kind an obvious fault. I'm looking to replace the boiler with a more efficient unit in the new year so now's the time to resolve my issues. We have a pump boosted shower running directly from the tank so we'd like to keep that but solve the heating problem in the loft.
Is it just a case of lifting the expansion tank above the height of the radiator or would i need to lift the tank also? Is there no auto air bleed valve I could fit to resolve the issue.
All advice and points of view welcome
Regards
Paul
Regards
Paul
