I have a radiator in my en suite which I'd like to change for a towel warmer. The current pipework comes out of the wall behind the radiator from the center...like so
So to fit a towel warmer the pipes need to come out of the wall 500mm apart at right angles to the wall.
However this in an brick wall and there is only just enough rooms for the pipes let alone space to create a right angle.
What is the best solution to get the pipes into the correct position? Do I need to create space (grind the blocks)? or add a right angle to the pipe through some sort of adapter? Thanks
