I currently have at the bottom of my garden a lowered decking platform that runs the full length across of the garden and is parallel to a stream the otherside. This platform is about a metre lower than the garden & has steps down to it. What im planning to do is raise half of this decking up to the current height of the garden (so will be around a metre from the current decking).
I am after some advice as to what sort of joists/suport posts will need to be used for this sort of project. The size of the decking will be around 3x2m.
The surround for my current decking is made up of railway sleepers stacked on top of each other so I was planning to use these as the support for 2 sides of the raised decking and then will just need 2 joists to make up the square, the internal supports (bearers) and a post to support it all in the other corner (or maybe more than one?). The ground this post will be going into is right next to a stream so it will need to be something strong & secure!
Do I need special or bigger joists/bearers for this sort of thing or is the normal stuff suitable?
Any help/advice is much appreciated.
