Advice -Levelling upstairs floor after settled subsidence?
5 Jan 2009
Hi all
Renovating one of my properties I purchased 15 years with subsidence at the rear extension (28 years old). Property is over 120 years old.
When I first purchased it I made do by literally screwing 2x1 roofing battens at the back extension on top of the existing floorboards/cut packers/wedges form same. Screwed them down into boards and covered with 18mm 2400x600mm chipboard.
I'm now in a position to do it properly and the there has been no movement since I done above.
There is a fall of 2" / 2.5" over a span of 3.7m.
I have take all the old temp levelling I put in quickly when purchased and now want to go directly onto existing joists to level it....
What are my options?
I did consider furrings but they are a set degree/slope.
I also want to go on top of existing rafters to prevent t noise/movement and perhaps use some composite glue as well as screwed/nailed.
Cheers
Just screw strips of chipboard to the side (or both sides of each joist. There won't be any noise or movement if you do it properly.
Take up floor and sister joists to level , lay new floor. Though a slight slope would not bother me unduly as long as it’s flat.
