Advice needed: Attach plastic shims to joists?
10 Sep 2007
Cambridgeshire
For my outside decking have joists sitting on slabs. Need some spacers to get peefect fall and height. What is the best way to stick plastic spacers to underside of the joists so they don't move over time?
Could gaffer tape them but guessing that could detiorate.
You should not need spacers the joists should be hung off the cross timber to the correct height to give a fall.
A couple of galvanised brad nails through each one? It's only to stop them sliding out from expansion and contraction of the timber, right?
Gaz :)
Gaz,
Could do but that means lifting up the frames rather than just sliding some shims under with some sticky stuff!
Maybe your idea is just safer in long run.
