I'm replacing my bathroom suite and have decided to renovate the whole room while I'm at it.
The bathroom walls were tiled up to approximately 1000mm from the floor and when I removed the tiling, quite a bit of plaster came off the wall as well. This is old plaster (grey, crumbly when you scratch it), possibly original - and the house is about 100 years old.
Now, I want to put up tongue and groove (T&G) panelling up to the same height all round, so I'm not concerned about how the bottom half of the walls look; I just need a surface good enough to fix the T&G panels onto.
Does anyone have any advice on how to do this?
How should I treat the surface in order to be able to fix T&G panels onto it?
Obviously I need to remove any existing plaster which is loose, but what then?
Thanks in advance for any advice!
