I've been asked to skim a conservatory and saw it before the walls were dry-lined. I've done a search on this site and found the pic of permitted zones for unprotected cables to confirm what I thought,and the diagonal cables were not covered, as isn't the cable at floor level running around three walls, nor the supply cable dropping down the wall. The wiring was done by the owner of the firm who is not a qualified sparky. I told the house owner that they should be protected but the guy argued and said they didn't so I don't know what to do about it. The supply is not connected to the CU yet but he has left the cable next to it. There is a spare way blanked off which he could use but I don't know what he intends fitting. This supply cable is a single 2.5mm so my understanding is that as it is a radial circuit, then it should go from a 20A mcb; or if fitted as a spur from the kitchen ring then it should first go through a 13A FCU. Is that correct?
The other thing I'm not sure about is the wiring to the light and ceiling fan. The cable from the left socket box is 1.5mm so should that first go from a FCU first? I know you wire a fixed appliance from the ring through a FCU but can you also have a FCU from the radial circuit.
The last issue is the outside waterproof socket which is spurred from the right hand socket box and as the CU has 100mA rcd so this socket should have another 30mA rcd protection. Would it be best to wire the whole radial circuit through a FCU 30mA rcd so that would give protection for the diagonal wires if anyone drilled into them?
I'm not happy about all this but what do I do? Is this guy actually breaking the law doing this stuff not to regs and/or not being qualified?
Any advice appreciated so thanks.
