- Joined
- 8 May 2017
- Messages
- 10,617
- Reaction score
- 2,857
- Country
Don't get bogged down with the positioning of the pipework to these rads ,fact is they have worked fine for years ,haven't they ? The lockshield valves on all your rads are used to basically create resistance to flow thru each rad. As the water is pumped around your CH it will always follow the path of least resistance. So if you have some rads that are not heating ,because the system is not balanced and no other issue , then the lockshields on those rads should be fully opened ,and the lockshields on rads that work fine would be closed down ,partially ,little by little. Thus having the effect of increasing resistance to flow thru those working OK ,and allowing increased flow thru the rads with fully open lockshields. That's the basic Jist of it .
