Advice on connecting a second tv/aerial connection
21 Jun 2010
Berkshire
I am currently having my loft converted and I want to have an aerial/tv connection in the attic from the existing aerial on the roof.
How is the best way to do this.
The signal strength will be reduced if shared between multiple TV's, so, you could use something like this. Connect your existing aerial to the 'input' socket and connect your existing TV to one of the output sockets and the new TV in the loft to the other output socket.
Other versions are available with more outputs so you could add more TV's later should you wish.
The splitter needs a mains power supply, and is usually best located in the loft near the aerial.
Sounds like a good solution, would I just cut the current coax cable as it passes through the attic and re join through the splitter?
That's the idea, you will need to fit a coaxial plug / socket to the cut ends. This will depend upon the splitter you buy.
