I want to make a breakfast bar which has a 1500mm ash top, which is partly overlapped by the end of the kitchen worktop. The base needs to be eventually a sheet of stainless steel (purely cosmetic) which literally wraps around whatever load bearing frame is supporting the top.
How's the best way to make this – I presume some sort of thick plywood circular base fixed to the floor (concrete) to establish the diameter, with multiple studs fixed to it vertically? But a presume a few diagonals will be required to prevent it from twisting of tipping sideways?
