Hi, I've finally got around to tackling the damp problems in the living room, main issue was a damp chimney breast (paint kept pealing off and what I assume is salt patches) however once stripping back everything I found lots of floorboard rotted which at the edges crumble if you push them with your finger. A few joists also have signs of dry rot.
This is a ground floor suspended timber floor and the house is a 1830's stone mid terrace. Looking at the neighbours house, originally the floor would have been stone flags laid straight onto the ground.
I'm now in the process of replacing rotted floor joists and replacing the floorboard's with ply or chipboard while also insulating with wool. I just need some advice that I'm going about this the correct way. At the moment there is no dpm and the joists sit directly onto brick pillars. Usually there is a puddle of water that collects in the middle of the sub floor, which has dried up at the minute. The ground is also covered in mold/salts. Will just fitting a dpm to the joists fix this or is there anything else I need to do?
Also there two vents on the front of the house, however at the back of the house there is a cellar and the sub floor is vented into the cellar, the cellar has been converted into a room and has heating. The cellar is then vented through the old coal shute. Is this an issue having a warm room vented into the sub floor?
