Hi Again,
Just after some reassurance.
My detached garage appears to be a spur from the house ring main. It operates via the ring main MCB. (I do not know where on the ring the spur is taken from, (No FCU’s visible) but it travels underground to the garage where it goes into a garage consumer unit.
The garage CU has two MCB’s one for the lighting and one for the sockets. The lighting consists of, 1 x fluorescent, 2 x 60w bulbs and an outdoor PIR activated light with a 60w bulb.
There are three single sockets that power a freezer, dehumidifier (operates 4hrs a night on a timer) and a battery charger to keep the caravan battery topped up. Occasionally we might plug in a vacuum cleaner to do the car.
I am intending to replace the sockets with RCD sockets but having read other posts that a garage should be on its own circuit, wondered if mine is safe?
I am not worried about it not meeting current regs as it was all done years ago and to fit it on a separate circuit would involve lots of channelling inside the house & digging up concrete driveways etc outside.
All the wiring in the garage appears in good order, it is not rubber covered and is protected in proper trunking. There have been no known problems caused in the past, (No MCB’s tripping etc.)
I know that you guys can not give a definite answer just from a description but what are your thoughts? Does it sound OK if not ideal or should I start digging up the drive and getting the bolster chisel out?
Your views will be greatly appreciated.
