Hi I have installed a duck pond and this needs emptying frequently, I have purchased a pump on Ebay and will use this as an inline pump to just empty the pond. My question I dont want the wife to just switch the pump on and walk away then messing up the pump. or switch it on with wet hands etc.. Should be the other way around wife first then pump. Can i either have a switch we need to keep pressed and if so what is this called or can i get a switch as a timer so i can time the pond emptying and set this up.
This will not be wired into the mains so i assume i am allowed to do this havnign a switch between the cable and the plug ?
Any advice would help.
Cliff
Cliff
