Yup that’s the best thing.So, I use SP101 to go over existing floor then screed up to that level in porch area then final screed over everything? Do I need to caulk in between SP 101 boards and prime all over?
Trying to find SP101 local to me but no luck. Online firms looking at £35 delivery
Wish I had known this when I was levelling an outside undercover area, probably about 50mm but a steep drop 2.5m x2m to be levelled from a bigger area. But it just kept eating and eating bags and bags of the stuff the the OP I wouldn’t attempt levelling that deep again but adding the chippings sounds like a good ideaYou can build the height up with self leveller and bulk it with granite chippings, or, use a cement/mortar.
MerseysideWhere abouts in the UK are you?
Merseyside
Cheers. Just called them but will only sell to trade
Not much. About 5sqm. Will have a look. ThanksHow much do you need?
Jewsons sell a 5.5mm Flooring Grade ply which will be fine as you are using a finishing coat screed over the top.
