Hi all.
I am currently having a conservatory built. It will be 4x3.5x2.9 to the peak.
I have worked out that the heating that i require will be 2.6 to 3KW can any one confirm that this will be ok. one wall solid (with small windows on top) the other two glass with dwarf walls and a polycarb roof.
I have finally decided to extend the central heating in to the conservatory instead of using electric as i do not like the smell from electric heating and they also look a bit naff.
I asked the builder to leave a channel in the floor for the pipes but he has informed me that normally the pipes are placed behind the plaster board if the brick work is not left exposed.
I am going to install two radiators one on the house wall and one on the far wall of the conservatory. my plan is to run 15mm pipe down from up stairs then tee off on the first radiator in 8mm to supply the second. The radiator from this will be 1.755kw(5988btu) i have read that 8mm max is 1.5kw the maths says its not large enough but could it be ok?
From the tee off to the radiator is about 6meters is this another issue if the pipes are ran together should they be separated?
i have not ran micro bore behind plaster board before but would like to keep it as close to the wall as possible how do i install the pipe? capping? plastic coated pipes? behind the skirting?
Your advice is much appreciated.
