advice on new toilet
19 Sep 2013
Buckinghamshire
Hi
We are looking to replace out toilet as the current one has a very weak flush to it, we have tried different syphons and found the best thing to use is a flapper valve but it still doesn't have a powerful flush and sometimes requires 2 to 3 flushes. We have taken the cistern apart and are sure the problem is a bad design to the pan's entry hole for the water. Pressure is good and not a problem with filling.
Also the cistern produces a lot of condensation on the outside but this is another problem to solve.
I am looking to purchase a Roca New classical toilet, partly because it looks similar to existing bathroom suite and have seen roca toilet flush and they seem powerful.
Are all roca toilets powerfull? Are there any other manufacturers I could look at the come recommended?
Both of our toilets (along with those in previous houses) require two or three flushes to clear things when I 'go'. I'm beginning to suspect it may be a natural feature of my poo.
Why not try a full bucket of water to fortify the toilet flush?
I thought 'floaters' were those thing that whirl around in your eyes - not your toilet bowl.
Thank you everyone for the in depth technical replies... :lol:
I had a feeling I would get replies like this when I was writing the post
Check u haven't got a bit of diaphragm stuck in the inlet of the pan.
I had the same problem.
Every single visit (no. 2) was blocking the loo.
I found out I wasn't drinking enough water.
More water, softer shoite, softer shoite, easier flush...done!
No, mine don't block the toilet, they just won't go away. :oops:
Several pints of Bass before retiring to bed. That will sort you out. And you won't need an alarm clock neither. :shock:
  • Thanks
Reactions: JBR
