Advice on stud locator
21 Nov 2005
Sheffield
Looking for best way to locate a stud so I can hang my tv, tool ? or knocking on the wall ? which is best way ?
Make a small hole, which will be hidden by the TV anyway, and then use a wire coat hanger to find the studs on either side, then you have the spacings
Or look/feel for the board joints or nail heads - or find the nails with a metal detector
You can often see a shadow where studs are and occasionally the screw or nails heads.If visual inspection revels nothing then a fine screwdriver blade pushed thru every 40mm will locate.
Stud finder can be very inaccurate.
http://www.amazon.co.uk/Neodymium-Magnetic-Magic-Puzzle-Pieces/dp/B004FGIY6W/ref=sr_1_1?ie=UTF8&qid=1346460658&sr=8-1
Works for me most times - leaves a spread of magnetic spheres to allow a line of best fit to be drawn. Clean and efficient, and then the entertainment of getting them back in the box :) :wink:
How does that help you find the stud? put one ball behind a hole in the plasterboard and move it around with a magnet on the outside? or something else?
Those should be strong enough to grab the plasterboard screws through the plaster.
