Hi
Please could I seek advice on the following points:
1. My consumer unit is supplied directly from the base of the meter, ie not through an isolating switch. If I request an isolating switch will I be responsible for any costs? Will the supplier do this at my request, ie customer rather than a qualified electrician?
2. I have a new (unused) MK box (isolator with only room for one double switch) fitted with a 100A Main Switch (5500s) is this the type of isolator I should have and would the supplier connect to this? Is this sensible or should they supply and fit?
3. The earth from my consumer unit wraps around the soldering of the suppliers cable (ie. the bulbous part of the supply) but appears not to be bonded. Apart from wanting to fix this asap for my own safety, whose responsibility is it and would an earth rod help / be preferable?
I am in Epsom Downs, Surrey and supplied by EDF. I mention this to clarify I am not in a rural location
Thank you for any advice, apologies for lots of questions!
View media item 37560
