Hi there, I am after some advice for an upcoming wedding bash in two large marquee's.
I need to run 2 extension cables from the house to the marquees. One length at 45 metres, one length at 55 metres.
The shorter length is powering JUST a disco (with lighting etc). The DJ has said they need a MAX of 3500watts/15amps and just two standard 13amp sockets.
The second, longer length is powering 6x60 watt light bulbs, 6x10 bulb christmas light sets, 2xlow voltage 'icycle' style gutter christmas lights and a second small PA system (not sure on the ampage of this yet but can't be as high as the disco itself).
I was thinking of buying a 100metre reel of 1.5mm (15 amp) artic blue cable. The shorter one, powering the DJ, will be plugged in to the main socket that supplies my oven.
The second lead, I think will just go from another socket in the house.
As nothing will be on in the house at the time of the party am I ok to use a standard 13amp socket to power the 2nd extension?
Its an old house and no doubt the wiring isn't the greatest. I know the cooker has its own fuse and a master socket/switch so that will be of a higher ampage (20?) but will a normal household socket be ok for the other extension lead.
Does this all sound feasible?
I was thinking of installing RCDs at the marquee end of the leads rather than at the house end. Is this ok?
Any advice appreciated? (Such as should I go for 2.5mm wiring or would this be overkill?)
thanks in anticipation!
David
David
