aeg integrated wash/dyer drum stuck belt snapped
6 Nov 2008
Staffordshire
integrated washer dryer L14710 today i noticed the drum did not go round when i got my washing out
dad has had a look and the belt has snapped
Q1 how do you get to the back of the machine to replace belt??
also, dad worried as drum is so stiff
Q2 how do you get to the drum? what could it be
machine only 2 years old but not under warranty and was nearly a grand!!!
HELPPPPPP
Has your Dad actually looked in the top/back of the machine to see if the belt has come off?
If the belt comes off the drum would usually spin very fast and freely.
yes, Dad took top off machine and we saw the broken belt. we fished it out!!
but the drum is still stiff................
as its integrated it looks hard to get into aswell
I can only think something has got stuck in between the inner drum and outer drum if the drum is stiff to turn. Does it make any noise when you turn it?
There should be a back panel you can take off. If not look down the side of the machine. If it has a split down the middle it may be a model where the outer shell of the machine splits in two. There will be some bolts hidden behind some plastic disks.
Obviously remember to unplug the machine and make sure the water pipes and outlet pipe are long enough when you pull the machine out.
great thanks, ill let dad know.
yes the outer casing is split in two
i hope its just something simple!! would that cause the belt to snap then? something caught in between drum and casing.................
thanks for help so far
ill keep you posted
Check the pulley on the back of the machine.
There may be some of the belt cord wrapped around the pulley, preventing it from turning properly.
