I'm trying to fix some wall cupboards. The walls are dry lined, 12.5mm plasterboard over ~10mm air gap. The wall I reckon is aerated blocks with a skim of plaster undercoat, at least the opposite side wall was like that. I used fisher universal plugs a 10 x 3in screws. The plugs I hammered fully in with the end of the chuck to make sure they were in the block. About 2.5 of the screw is in the wall so must be 1-1.5 of the screw in the block. One cupboard has held and the screws pull tight. The others have all failed so now I need a solution to repair the failed screws. I also wonder if I've hit the mortar bed and that's why the fixing has failed.
I was thinking about some sort of resin fixing. Drill out the plug of course which would make the hole bigger too. There seems to a bit a lot of different resin tubes on screwfix. Would any be suitable? Most seem to be for fixing a stud in but I need to have a screw fixing.
Any suggestions of products that work and how to go about it?
