Folks
Further to a previous post, I need to fix a handrail to a staircase wall on brackets. The plaster under the new skim is fairly brittle but the brickwork below is reasonable.
Plugs have generally failed in the past as a large part of the plug is in the plaster. I was thinking about setting the fixings in resin anchors but every 'guide' I find only refers to bolts and rods being used with resin anchors.
My thoughts was to drill the holes, install the resin anchor and then screw in the bracket and hold it til it cures (assuming that I can get a quick curing resin!). Has anyone tried fixing screws into resin anchors?
Grateful for any input.
