Hi
I wonder if anyone can help me.
I have a roof aerial which comes into the loft space and into a powered splitter which has 16db, 12db and 8db settings on it.
I have co-ax running outside from this to the dining room (ground floor) where there are 2 aerial sockets on opposing sides of the room. Both of these are 'good' and can run a freeview television.
The kitchen next to the dining room has a tv in it which i want to connect to the aerial but need to 'split' the feed from one of the aerial sockets as the other one is too far.
I bought a Y splitter but when i use this it doesnt not work (not enough power i hear you say). The box for this feed is set to 12db and i upped this to 16db and still nothing (also tried it on 8db and nothing).
I thought initially it was the 10m cable i had going from the Y splitter to the tv but changed that for a 2m one and still the same.
Currently i am using the other aerial socket with the 10m cable and it works ok but cable everywhere.
I guess i need some sort of powered Y adapter, anyone want to recommend what i need and if this is the problem?
I bought a second Y splitter just in the case the first one was broken and its still the same.
Lee
Lee
