Does an air amittance valve have to be fitted vertically & above the discharge stack?
The reason being is i'm installing the pipework for a proposed downstairs toilet unfortunately i cant fit a conventional soil stack arrangement (vertically)
I'm proposing to come from the toilet into a 90deg pan connector then into an equal tee one end connecting to main pipe which is connected to a mini access chamber, the other end of the tee is connected to a short horizontal pipe then a 90deg bend, up the wall for a approx 1m then capped with air admittance valve, in your opinion(s) will this work?
Any advice greatly app'd
Tim.
Tim.
