Air Con HELP!
13 Jun 2006
Renfrewshire
Anyone know anything about air con, I have a citroen xsara and when I turn on my a/c the power light comes on and the rev's dip but no difference in air temp? any help appreciated
Re-gassing is cheap but it's possible the compressor has failed in which case it's expensive if you can't find a 2nd hand one. If the revs change I would guess it needs re-gassing.
If the engine revs drop then it sounds like the compressor is working.
You can buy a re-gassing kit from halfords and do it yourself.
If it wont hold the gas, then there is probably a leak somewhere. Most common leak places are where the aluminium pipes are clamped back to the car body as they vibrate and wear through the pipes.
likley to be pipe going in to bottom of condenser or condenser its self
