my idea for an air con system. any feedback would be useful
get a freezer and put a large tank inside it. fill with water (with antifreeze, unless you have any better ideas). put this in loft (if your limited for space, like me)
get a old car radiator and a water pump. pump water from tank thru radiator and back to tank. put a fan behind radiator. and you have a workin air cooler. hopefully.
so, questions.
use water with antifreeze or something else?
for gettin pipes from freezer, whats the best way to do this? drill thru side and fill gap with expandi foam?
would it also be worth adding more insulation to the freezer?
note: i will only be using this a few hours per day, mostly when i get in from work so hopefully the water should be cold enough after bein left all night and most of the day
so, questions.
