If you hav'nt let your master cylinder go too low with fluid, and you have air in your system(how do you know it's air) then it suggests heavy braking causing boiling of the fluid, causing the drum to get hot and a slight distortion of the drum,, could be air in the front, bit of a wobble when braking, this is how it USED to be, maybe things/boiling points of fluid have changed
