Air in hot water system
30 Apr 2009
Sussex
The hot water supply to my en-suite had to be routed via the loft space meaning it goes up from the hot water tank , across the loft and down into the floor cavity before rising to the sink and bath. I have installed a bleed screw to expel air but every few days air collects and the sytem needs bleeding again. The pipe run is below the cold water tank. Any suggestions?
Install a t piece in the pipe in the loft and run a pipe from the t back to vent over the storage tank.
Years ago in long properties they used to stick a secondary vent pipe out through the roof.
But of course im not sugesting you do that ;)
As cider suggests, at the highest point in the horizontal run, but make sure the highest point of this secondary vent is the same height as the existing vent pipe.
