I'm in a council house with what I think is called a back boiler / gas fire system.
When we run the hot tap, after a while it will start to cough and splutter as if air is in the pipes however it only does this when the tank in the loft is low.
Is this normal? Also is it normal for a radiator to get warm (not full heat) when the hot water is turned on but the heating pump is not.
