This is not a central heating question!
Cold water tank in loft feeds ground floor bathroom with bath and shower. If you run the bath on full it will drain the hot and cold tank before its full and this means the pipes to the bathroom fill with air. When I go to use the bathroom sink taps they splutter till the air is run out and if you try and use the shower (mechanical thermostatically controlled) it won't run again until the air is cleared.
This is a real pain in the a=hole!
I understand a larger cold water tank should fix it but would it be possible to either:
Reduce the draw on the bath taps so they fill slower or
Fit some no return valves on the pipework to the bathroom so they don't empty?
Any comments much appreciated!
Cheers!
Cheers!
