- Joined
- 8 Apr 2005
- Messages
- 6
- Reaction score
- 0
- Country
I have installed a pumped shower system. I used a seperate feed direct from the cold water to the pump and a separate feed from the hot water tank to the pump. The connection to the hot water tank was using a techflange that has a pipe that slopes upwards into the middle of the hot water tank. It then goes down into a u-bend and then an n-bend (inverted U!) to get to the pump inlet. The pump is slightly below the level of the flange output from the tank but the inlet is above this (but still well below the top of the hotwater tank). I have an air bleed valve in the n-bend.
All this is below the level of the coldwater tank.
The water is then piped from the pump, up into the roof space and then down to the shower.
The problem is that every time the shower is run air accumulates in the n-bend and has to be bled out. Also when the shower is turned on it takes several tens of seconds for the water to start flowing (the pump has pressure switches and the pump does not switch on for this period of time).
Any ideas how I stop air getting into the Hot side of the system? Why does it take so long for the shower to start when switched on?
