Hi - We recently had our boiler changed and the pump was moved due to some problems with water circulation at the same time, although there were no issues with water with the old boiler. Since this time the radiator that is the last on the system, this radiator is in a loft bathroom, gets air in it very quickly and needs bleeding nearly daily.
Based on other posts i wonder if since the pump was moved and most likely adjusted is it possible we are now in a situation where the pulp is set too high and its pulling air into the system? I dont think anything is leaking anywhere as i dont hear the header tank fill with water.
I have attached a photo pf the pump as i am unsure how to turn the flow down or in fact what its currently set to.
thanks for any advice
View media item 69959
