Have an open F&E system.
Had a few problems recently with the central heating. - Primarily clanging, whooshing noises.
Thought it was due to the pump - so I replaced the pump.
Next pilot on boiler starting going out - So got someone in who replaced the Thermo-couple, as system was overheating.
This resolved banging and pilot issues, but now get alot of air in rads.
Have turned off pump - bled all rads, bled HW cylinder, bled pump. But air is still an issue. Bleed every other day.
I noticed that the pump is on all of time - even when the heating is off. Is this right? or should it only kick in with the program/timer? Could this be causing my air problem.
PS: when rads are bled they work fine (heatwise)
Thanks for shedding any...
