Does your thanks button not work?
Expansion and contraction keep the water moving, all day every day. As opposed to dedicated feed and expansion.Why does combining these solve the problem? Water circulation preventing build up ? I ask as I have a similar problem.
That's how I've dealt with it for a long time now and as yet haven't been back to one with the same problem.does joining the feed to the vent also help to stop sucking in air or are you saying that removing the piping that has the manetic sludge in it will solve the air problems and that joining the feed and vent will keep water moving on expansion and contraction stopping iron biuld up in the future?
Thanks,
Kevin
Draining the system can pull debris from the tank which would compound the problem.Thanks for the advise, I still plan to cut out the pipework and replumb as you said on the weekend. The only thing I can't get my head around is I never had the air problem when the old boiler was in place. Do the new boilers these days show up this air problem much more then my old one did?
Thanks,
Kevin
Wherever it's easier mate. Let us know how it goes..Thanks, when I connect the cold feed by teeing into the vent would you recommend a perticuler dimension up the vent pipe (eg 6" up from horizontal flow pipe)?
