just doing the new pipework, it did have a lot of magnetite around the cold feed/vent area.
I have cleaned around that area as best as I can and have made sure my F and E tank is clean.
Done the pipework, filled up again with water and checking for leaks.
Should I try to flush through again before adding inhibitor?
My water runs clean when I drain the system down, even though it was full of magnetite around the cold feed.
Would you call a flush opening up a downstairs rad and drain off while the F and E tank is still filling up, so it flushing through for sat half an hour, or do you think this will be no help?
Or do you think I should just add inhibitor once I no I have no leaks, bleed and job done.
Appreciate your advice.
Thanks,
Kevin
Thanks,
Kevin
