I've got a shower pump, the pipes are all as shown in any diagram i've seen, with the exception of the pipe coming out of the top of the HW cylinder, which splits to taps and shower at an equal tee. I'm getting quite a bit of air through when drawing hot water, and this is especially affecting the shower pump operation (cold side pump is firing up, hot side isn't straight away).
From what i've been able to find I either need a surrey flange in the top or an essex flange in the side. Both look like they'll need a fair bit of work (pipes for the Surrey, scary cylinder cutting for the essex). As there is a ruddy great big hole already in the tank where the immersion would fit, is there anything which would screw directly into that and fix my problem? I'd have thought a j shaped tube dropping down from that into the water would do the trick. If not, I shall have to go with a surrey flange before another shower pump dies......
Thanks for any advice..
