I recently ran some cleaner around in my central heating system after doing some work, and then flushed and refilled.
As much as the system seems to be working fine now, and refilled ok etc, if I listen near to the pump in the airing cupboard it sounds like there is air in the water. Not an air-lock as such, but just as if there is air in the water, (if you know what I mean?!?).
I'm wondering if the vent pipe is blocked in someway and therefore not letting the air out of the system properly? I don't know what happened when I refilled the system, as I was downstairs, so for all I know the air may have exited the system by going back up the cold fill pipe.
When the system is running and up to temperature the cold fill pipe is hot for as high as I can reach in the airing cupboard, (presumably this is due to convection effectively heatnig the 'cold' water in the pipe?). However the Vent pipe feels fairly cool only about 1ft up from where the main flow T's off towards the fill & pump.
Other than cutting through the vent pipe to check it is there some other way I can check for a blocked vent pipe?
I was considering perhaps attaching a hose pipe to the cold fill & the outside tap (turned on slightly), and seeing if I could then cause the system to effectively overflow up the vent pipe, which would presumbly tell me that it's not blocked. My only issue with this is that if the vent pipe IS blocked then I would presumably be pressurising my system and I don't want to risk blowing any joints
I have run various cleaners through the system recently (X800, X400) in order to clean the system out and get heat to all the radiators (which is now working fine), but presumably these won't have touched the vent pipe as it's not in the main path of water circulation?
Any suggestions? Do I go for the hose pipe, or do I bite the bullet, drain the system AGAIN ( ) and take a cutter to the vent pipe?
